jrsavoie
Recruit
I use the license plate bolt.will do
A lot of times they were long enough I could add a nut and washer.
Depending on the heat sink, sometimes I would have rivet a piece of aluminum angle or something onto the heat siink to get it mounted the way ai like.
I took to mounting a heat sink and PMD inside each bumper nostril and running 2 extension cables up to the intake.
That way, I could swap PMDs under the hood instead of getting down on the ground
