Joefox97
Member
Good luck! Yeah, you need a mortgage just for the hookup. Oil leaks are a wonder. Most are pretty straight forward. But, then you get one that just stagers the imagination. I put a crate engine into my 84 Chevy, and it leaked out the front. Looked all over. Valve covers, timing chain cover, front main... Went on for weeks! Turned out to be an unused bolt hole by the fuel pump. They're drilled trough to the pump rod. Plugged it with a bolt, no more leak.
