FellowTraveler
The baro sensors came in many configurations know as a bar reading each bar is 14.7+- at sea level so the more boost in an application using baro sensor for fueling the higher amount of bar readings the sensor needs to be example 2 bar, 3 bar & 4 bar and up..And here I thought the gauge would be close to accurate at whatever altitude the reading is from, I always figured they`d self compensate from the resources available to them, IE, baro pressure, altitude or whatever other resources is available to them.
