Will L.
Glad you caught it.
Must be nice to have Leroy just a short drive away!last week, pulled into the drive, noticed a large oil leak. it was the oem cooler line that decided it had enough. added oil and still had 3 quarts left in the crankcase. Leroy's on vacation, just my luck. used plugs to block off but was getting zero pressure once warm. parked it.
changed the OPS with an AC Delco and made a relay for it.
when he returned i drove to his house in the Jetta. got the braided lines and new cooler. used less than a gallon of diesel and saved shipping. put them in last sunday: no leaks and 30 psi at hot idle.
i was sweating bullets hoping i didn't damage the engine or turbo. so glad i didn't have a longer drive planned for that day.
When I replaced theYeah if the chain isn’t stretched much sounds like it was refreshed or replaced.
Still factory cdr/ turbo? 1/2 pint isn’t bad.
Did you check out my raptor install? I made it fit in the stock location. And could easily go back to stock.
Thank You for the information Will. Much appreciated.The chain stretch on a diesel compared to gasser: on a sbc single roller chain is ok up to 9.5:1 compression. Above it recommended to go to double roller. Most people even at 8:1 will still invest in double roller on rebuilds and sacrifice the slight amount of added drag and power loss in exchange for longer chain life.
So if 8:1 is single wide link but 10:1 is a double link, at what point does double link become too low?
Yes there is a factor of power generated that causes the formula to slide up and down the scale, but..rule of thumb would says 12:1 is ok for chain (double roller), but beyond that gears only in gassers. Granted rare, but at that the boys back in the day quickly learned to copy diesel timing systems to deal with the compression related issues.
According to every builder of diesel engine except the 6.2/ 6.5. timing chain doesn’t cut the mustard. The ds4 is only on the 6.5 so it can’t be directly compared. But anyone on here know the lifespan of a db2 on a 6.9/7.3 compared to a 6.2/6.5?
We all know cam bearing life and oil pressure loss there on the 6.2/6.5 platform is a little shy compared to the ford counterpart. Granted the ford oil pump and system is setup very different. But I have long wondered about the chain slap sending the added shock wave into the cam and thus the bearings suffer. All the damaged cam bearings I have seen over the years is always #1 or #3 bearing which in gasser hot rod analysis says go from chain to gear drive if everything is straight and true. Hmmm.
Yes the chains have a large accepted tolerance spec from GM. Oil pressure is ok at 8psi cold idle- but are you happier there or 20ish? Injectors can be out of balance 10% by spec, but most of us know what being under 2% does for it.
And that chain stretched at 200,000 miles in your small block- the 6.2/6.5 hits that stretch in half the time usually.
Yeah, way convinced your diesel was refreshed at some point. The timing gears I got from Leroy for my optimizer btw, I didn’t get because I plan on hot rodding. I plan on longer cam bearing life and longer ip life. With the added bonus of keeping timing correct and no future chain replacement needed.
He might have started with a front one and once it started spinning assumed it was stripped. He probably doesn't know how that particular skid plate comes off.
@Big T and @snarl95
I agree with both of you. You cant fix stupid, and he probably just didn’t know. He should know his job, but to be fair- he is a “mechanic” or “technician” at walmart WALMART.
I don’t get upset at fast food places when my order is wrong or I don’t get service with a smile, nor do I expect to say “Wow, this is really good!”
For that I spend 3 times the cash at a “real” restaurant.
Walmart, pepboys, minute lube is fast food tor your truck. I’m bot gonna say they shouldn’t exist, or that the quality should improve. Even manual labor is a get what you pay for scenario.
Crappy knowledge of a variety of automobiles and the lack of figure it out experience, followed up by a low paid supervision middle management boss he answers to and goes to for “help” which shows the horrible pay and support that that guy/gal couldn’t figure it out. Top them of in the (probably same person) service writer taking rediculous time to explain it to you in a timely manner.
What was the price of the oil change- half that of a high quality shop with advanced mechanics to always do it right and quickly. When I owned the truck equipment shop we tried to avoid general mechanical work. But we had multiple accounts that decided we were worth it. Back when quicky shops were charging 13.99 for full lube, rotation, and oil change in the 90’s- we were charging our clients $100. I didn’t have rookies working for me. When you employ a guy that stops building a $30,000 engine for an oil change, it’ll cost you. But even if skid plate bolts really are stripped, and you need an oilpan gasket, you’ll get it back still on time with no leaks and nothing added to the bill.
And yep that “mechanic” at Walmart- will do all his own oil changes his entire life. Not by choice but by economic necessity. If he couldn’t figure out that, he won’t figure out the other obstacles in life. Nothing against or wrong with living paycheck to paycheck in my eyes. But dude’s choosing to be a mechanic and couldn’t figure that out? No. If he is an IT guy, or plumber, ok. But mechanic- c’mon man!
