That's an interesting comment about the airflow cooling it when not under boost.Looking sweeet.
What are you going to run for coolant?
70% water 30% what coolant, and water wetter???? Or 50/50 ?????
One thing neat about W/A coolers is when low boost the air flow cools the water relative to high boost so rolling hills kind of normalizes the intake cooler during cycling loads. Are you going to run a tank for volume? How are you going to turn or or trigger the circulation pump and cooling fans?
That's true, I should only need it when towing, but it feels stronger driving around when the ambient air is cooler so I'm thinking I'd like to have it running all the time so I can enjoy cooler denser air all the time.only time you should really need it is when towing
Hmmmmm, how do I test for static electricity? Just a VOM looking for small amounts of voltage between the component and ground?I'm not sure what on this, I was wandering what mfr recommends or what general consensus is of experienced owners. I would guess just a bottle of water wetter then 50/50 antifreeze and water mix.
I'm thinking you should test for static electricity being generated and ground out components as needed to slow electrolysis corrosion as much as possible. I am 99.99% in love with this idea. Only thing that scares me is heat exchanger failure allowing leakage into the intake causing hydrolock.
I still have the CDR. I turned it around so it's pointing towards the firewall and it's hooked to the oil catch can with Gates multi-purpose hose.Did you have to loose the CDR?
Do you guys think a IC made with a functioning A/C evaporator core would work. Kind of like a dual air Suburban, but instead second evap as the IC.
