Paveltolz
Доверяй, но проверяй
Everything about the P400 is heavier duty.
Main girddle, forged crank, rods, heavy duty pistons, metallurgy......and its all brand new (not rebuilt) not sure if heads would be different though??
Heads were redone as well with better alloy mixes and castings. From what I've gleaned, the heads were actually first having been tested in Afghanistan where the military was killing the the old design in connex loads each month. After several months of testing, the blocks got the works too.
The P-400's oil pan is part of the lower end strengthening and the old pans aren't interchangeable. Not exactly sure why either but, at a minimum there's a difference in bolt patterns which would be easily overcome so there's something between the old and new blocks making the new pan a necessary inclusion. I've heard of a couple of designs out there to making them work for both the C and the K models. Mostly it's been write ups that involved modification or have a 'one-off' made for you.
