I dont really know how trust worthy it is in a truck with a wiring fault but the water in fuel light comes on for a couple seconds like normal then goes of off once ignition is turned onSo fuel in tank needs to be checked. Run lift pump with water drain open into a glass jar, etc.
Likely wouldn't start and they killed starter trying.
Rebuild your starter or get a powermaster. Lots of junk out there that go thunk and won't spin 1 of 4 times. Low bats can burn a motor out. More important won't get enough RPM to ever fire off thr diesel.
No way would i even try running 10 year old fuel anymore. Back in the day with real #2, yes. But the new diesel gets a lot of its umf from alcohol in the Diesel. Even in perfectly air tight all metal container, the alcohol looses its function and you don’t have descent fuel in there now. Drain it and get 5 gallons of new fuel. Drain it all the way through the filter and wif drain.
Get a clear 1/4” line on the return line coming out front of ip. Truck sitting that long without the fuel circulating through the rubber lines-- probably cracked and sucking air if not happening now is probable in the next 12 months. The clear line will id air intrusion. What does the fuel filter look like? How long was it sitting?
New info. This exact style switch was on the truck the first time I messed with it. (I know its just a master disconnect....) Went from ground on starter to I don't know where else. I put 2 fresh batteries in it that night and found this switch. When I turned that red key it started cranking on its own. The keys were in my hand. I figured cylinoid at first and still am but my problem is there is a 12 gauge wire that goes from hot post on cylinoid to hot post on battery. Makes no sense. I can't figure this wiring out. In the video of me trying to crank at the end the horn honks. I didn't hit the button on the steering wheel. Serious wiring issues or something simple that Im overlooking? Took sandpaper to both grounds for both batteries. I can add any pictures that might help yallLow voltage will cause a selenoid to stick. Seems to arc the contacts worse.
So the 12 gauge wire is in parallel with the 4 gauge wire? If it's hooked to the small terminal it would cause it to crank all the time but if it's hooked to the same terminal as the big 4 gauge wire it wouldn't do anything.
Can you post a bunch of pics? Start at batteries down to starter then maybe we can see what’s up. Sounds to me like they had a battery drain then installed the switch to save batteries from dying. Eventually the faulty starter solenoid fried all the way and went from just draining the batteries to cranking all The time.
Ok Ill trace it and let you know where it goes toI'd trace where that wire my finger is pointing to goes to on your truck
Where should it go? Seems to me like it goes to the starterI'd trace where that wire my finger is pointing to goes to on your truck
Ok I figured out I have no power to the fuse block under the dash. There is one round plug that has power but I think it’s for the door switchOn unaltered wiring it goes directly to that wiring block without going to the starter. I believe that larger piece on there is a fusible link
One of those wires that was on that master has power constant but that block can’t get power with out a wire on it or a different wire touching the battery. I’m beyond confused I’m headed to look at A parts truck maybe I can get something figured out if not I’ll let y’all know where I’m atDon't have a diagram but I believe that wire supplies power to that block.
The wire you wanted me to trace goes to the battery on that truck of my dads. Copied him and still no power to dash. I do have power to that block now. No fuses are blownI'd trace where that wire my finger is pointing to goes to on your truck
Thanks for the help think I'm just gonna go push it off a cliff lol no probably gonna try to just sell it this is way out of my expertise and I'm getting tired of messing with it. Thanks for the help thoughDon't have a diagram but I believe that wire supplies power to that block.
