- Staff
- #41
I have the tool. Bought it from Snap on many moons ago. It's specifically made for grease hub cap removal.
From skimming my manual the bearings need packing. There may be some oil in the closed knuckle as well (which is totally new to me) as the manual lists a fill plug in it. I haven't gotten there yet. A lot less oil came out on the passenger side than the driver. The manual also lists seals as felt. I am definitely going to remove the pumpkin cover, drain and refill with new fluid following new seals. Good point on the breather, will have to check it for any obstructions.So you have a grease packed wheel bearing and it had some oil in it also. You need to find in manual 100% that it shows IF the bearing is supposed to be packed in grease.
If it does, then you need to find the measurement of oil that is supposed to be in the differential AND if there is supposed to be an inner axle oil seal.
If the differential is over filled, that oil makes its way to the grease, washing it away and damaging bearing. If the diff housing breather gets plugged it can cause pressurization and force oil out there also, so ensure that is clean.
Some oddball axles ai messed with had simple rope seals, a Brit truck had one that went in before the outer bearing. An old Overland one had rope seal right by the pumpkin. Problem was in both cases by the time I was rebuilding them, someone before me rebuilt it and didn’t reinstall them. The only way I noticed was the issue you have now coupled with rub marks on the axle I could see when fully disassembled. Some axles use regular seals instead of rope btw.
The problem with older toys and no manual is learning how it was designed to work. Just guessing if it is oil bath bearings and not greasing could ruin bearings and snap axles/ diff gears. Guessing they are grease and that it was just over filled means under filled diff housing and ruining diff bearings and wiping out those gears. Ahh, the joys of classic cars that are behind the scenes-
Yes. I'm assuming just as you said either grease has broke down (due to the extreme cold swings of Massena, NY), wheel cylinder failure (and the seal allowed fluid past) or there could be oils still coming through the snout of the spindle (where the axle shaft comes through).Is that the set one that had the oil in with the grease? If so scratch what I said before. I thought we were looking at a live axle. My apologies. The oil could only have been two things. If the lre was brake fluid contamination if wheel cylinders leaked, or grease that just broke down.
