Well, I started on the 93 and figured might as well drop the pan and have a look. good news is there is absolutly no debris in the pan, but the fluid is quite dark. what do yall guys think...
before messing with my 93, I spent most of the day messing around with the Ole'Betsey the dodge ram. brought it in my work area and pulled off the throttle body. cleaned it up real good. then gave everything a good looksee. it needs quite a few parts. all of the hoses need replacing. the lower rad hose is rock hard. the radiator needs flushing as there is somekind of yellowish green growth on the inside of the cap. started cleaning her up. my boys helped me give her a good bath, then I pulled out the buffer and went to town on the red center stripe that was mostly pink now.
she looks good now with some lipstick... I am thinking about doing some gloss black rattle can to give the hood and roof a better look
Here is the before and after shots.
Before...
And After....
I replaced both the 1-2 shift and the TCC solenoids. the ones in there were not delco units looking at them the markings were different. I also noticed that the 3-4 solenoid is kinda loose on it's bracket. I think I will most likely order that one and the sensor plate that lives under the filter. poured the old fluid back into the trans so I can at least test if replacing the tcc solenoid fixed the problem of it not releasing.
while I was pouring the fluid back in, I noticed a leak!!! O-crap.. crawled back under the truck and found that the dipstick has a hole in it right behind the engine plus it's loose not secured to the back of the head. welp I bet the tab that's spot welded to the tube came off and now has a hole were it was spot welded. Great, grand, wonderful LOL
I guess I will add that to the list of repairs when I finish the other engine and when this one gets pulled. it didn't leak a lot, so I'm not pulling it out right now.
That pic I posted doesn't do justice as to how dark the fluid is. while I was pouring it back in it looked like used motor oil, you cant see through it.
I will make plans to change the fluid, though idk how to get what's in the converter out too. maybe when I pull the engine I can pull the converter and dump it and refill then.
Reusing the old atf is probably the better answer.
When a trans is new and regularly gets the fluid changed, you get the longest life. If it goes way to long without a change- when you do it the new atf has so much cleaning detergent in it, that it will scrub the grime off everything and start to plug the filter and passages.
The detergent will also cause old overheated clutch plates to loose the layer of crud on them that is ready to wear away - actually come off in big chunks. The world is filled with stories of people who did the first atf fluid change at 125,000 miles and the trans fails in the next 3 months.
Other people swear by no matter how long- do atf oil & filter asap and often.
That just hasn’t been my experience on a neglected unit. Imo so long as it isn’t suler burnt smelling oil- stick with it. Pour back in and add as little new atf as possible. Then plan the rebuild, because I can’t remember many people saying they were religiously changing atf every 30k miles and ended up getting 450,000 from it. They all seem to nickel and dime or just blow up - so I really don’t see the point.
I suppose if you are towing heavy often, it could pay off. But even then I think spending same cost of first service on a trans cooler is smarter.
4l80e- in the fleet we NEVER did atf&filter change. 300,000 miles plus always. We learned when it’s a transmission you plan to keep for decades- run it 200k to 250k then just pull for a rebuild. Change any hard parts in question and all new sensors.
The longevity of an auto transmission- especially the GM transmissions - its all about keeping them cool. Big T can tell ya- I was hitting the panic button with my 2001 suburban towing a small camp trailer near his town. My atf got to 210 or 220 (can’t remember which) and set a cel. I went to his place so he could throw a scanner on for me. And he laughed at me because i am not used to my gm transmissions ever getting over 205. All my pickups had KILLER atf coolers on them, just not my suburban.
This trans might have 10k - 15k miles on it now since it was rebuilt. the PO had it rebuilt back in 2018. I do have a temp gauge on it and have seen temps up in the yellow region of the gauge (don't remember the actual temp, but that might explain the dark color. there isn't a cooler on it other than what the radiator had built in. it might need an external cooler like my 95 has.
I was surprised to see nothing in the pan, even the magnet was still clean, though I have had the pan off trying to deal with the harsh 1 to 2 shift which I still have yet to figure out. it only shifts hard after the truck warms up, when cold it shifts smooth
I've not towed anything heavy but I do know the PO hauled around a travel trailer and did some hot shot work. if I can't figure out the TCC thing, I would assume it will be something in the valve body along with most likely the same thing for the harsh 1-2 shift and the trans will need to go back on a rebuilders operating table.
BTW would anyone know what trans would be in a 2003 1 ton chevy express van with a 6.0l gasser? if 4l80e, then I know where a good one is that might serve well for a replacement.
Ball joints.
Screwed up and ground the rivet heads just a little too far , then could not get them to budge to get a sight of the corcular imprint.
Ended it by pulling the upper control arm.
Heaven forbid, I hope to get it back on close enough to get it about four miles to the alignment shop without destroying the new front tires. 🫣😬 if not then I’ll need to borrow a pickup, load the truck on the trailer and haul it acrost town.
And rented the ball joint puller tool from oriellys.
I was absolutely stumped how that thing fuctions.
Did it the oldt fashioned way. Solidly support the LCA then pound the crap out of the ball joint.
Installation is the opposite.
Support the ball joint, get it started into the LCA then pound the piss out if the LCA. 😹
I dint hace a stick of round pipe so this square tube will work just fine.
NAPA fleet components.
New NAPA FLEET service ball joints dont fit. Upper dont fit within the U bend and lower is too small of an OD for the bore.
Damnit.
I could go to oriellys and possibly get units that fit, except for, I want parts that last even if I dont. 😬🤷🏼😹😹😹
Okay, off with the drive shaft.
Remind me to first set the park brake. 😹😹😹
Have a new center carrier rubber mounting bushing and also a complete assembly, in case bearing is bad, or good, gottit covered.
Now all the toys can go back into the box until time to drag some out for the ball joint excursion once again, maybe tomorrow, Monday.
Well the transmission is fixed on the 93!!
I took it out for a drive this morning and at first it was doing the same thing, get up to speed and the TCC locked in but wouldn't release. connected the display on the TCI controller to see what it was saying. sure enough it was keeping the TCC commanded on. if I got up to speed and just let off the pedal and allowed the truck to gradually slow on it's own it would release at about 25 mph but applying the brake it wouldn't release unless I lightly goosed the throttle.
pulled over to the side and decided to re-program the TCI TCM from start to finish (not that many steps to do). Then took off again. Now it's releasing as soon as I take my foot off the go pedal. I tested it several more times just by allowing it to lock and then let off and it would release.
I also came to a complete stop several times to see if the 1-2 solenoid did anything. at first it was still shifting harsh so I went back through some of the settings to reset the aggressiveness and RPM shifts. Now it seems to be shifting smoother from 1st to 2nd, still not where I would like it, but it's not jerking me on slow accelerations. this is what was annoying when your in stop n go traffic I would get a harsh jerk when it would shift to 2nd. that seems to have subsided a bit. max RPM shift it set to 2150 but I can only lower that to 2000 rpm, wish I could lower it to around 1500 to 1800 but that 's another subject. The main thing is it seems something screwy went on with the TCM and reprogramming it seems to have fixed it.
Update: Wayne has the ABS working on the ‘99 Suburban. The ABS has not worked since I bought the truck in 2010.
The sole remaining thing to do is to get 4 Low working. My wife dropped off her 4Runner plus two new AC Delco Encoder motors for the ‘99 Suburban. Hopefully, he can address the shifting into 4 Low.
Update: Wayne texted me saying the shift shaft to the transfer case binds, preventing it from shifting to 4 Lo. He could either tear apart the case to assess the shift shaft, or buy a new NVG-246 transfer case.
Transfer case was a new reman unit purchased and installed Spring of 2022 with 2-year and 70K mile warranty. I’ve probably put 20K miles on it since then, but time has lapsed on the warranty. Not so sure on this conclusion as it did not have 4 Low working on the previous transfer case. We have thrown dash switches, actuators, transfer case control modules, encoder motor and dash switches at this. I told Wayne I’ll just have to live without 4 Low.
I will talk to the rebuilder on this issue. Down the road I will have the transmission I took out of the ‘99 rebuilt and installed back into this Suburban. The transmission currently in the ‘99 will go into my ‘94 and the transmission in the ‘94 will get rebuilt. When I have it out, I’ll go through the transfer case.
My wife is down here in Fullerton for a follow-up medical appointment with her retina surgeon (all is good, eye is doing well after cataract surgery). She drove her 2014 4Runner “Priscilla” and I rolled it past 422K miles yesterday. Engine runs like new, same mpg, no oil consumption or leaks. Couldn’t ask for a better car.
Ball joint installation devices, using the weight of the wehicle as a sort if a press and the hammer to help persuade it to bottom.
And RH side us done except torque the lower balling, book says wait until wheel is attached and on the floor before torquing that snut.
And new center carrier bearing on the drive shaft. U-Joints all turns free and easy, OE sealed units.
I bought new stock length Monroe front shock absorbers.
Attached the top of the shock to the bracket.
With no front wheels/tires on the truck, jack stands under the frame, the length of the shock is still at least an inch short of being able to install the bolt through the lower shock to bracket.
Right after buying this truck I cranked on the torsion bar adjustment screws and jacked the front end up about 4”.
My plan is to get the wheels back on, drop the front end to the floor then back off the strut bar adjustments until the front of the truck is dropped that 4” so that the stock length shocks will fit onto the truck.
Is it normal for shocks to be too short to reach both mounting brackets or is it because I’ve got the FE jacked up so high ?
Raising the suspension by 4" might require longer shocks. you want the travel length to sit about in the middle when the truck is on the ground so you don't bottom out up or down.
Yeah, I had installed 4” over Rancho shocks but now am ready to drop back down the front end, readjust the torsion bar adjustment bolts. Get it back to factory ride height.
After I get the truck tires back on the floor I’ll drop the front then with the shocks still not fastened at the lower end. Check and see where the center of travel will be.
