Will L.
100% DO NOT add that kit.
What thermostat are you using?
The stock one sir, hasnt been changed since I bought it100% DO NOT add that kit.
If there is a forward switch from the front seat then try that, if it still dont function then Check the fuse.On today's episode of "Whats up with the K5"
It WAS LITERALLY working this morning![]()
Ehhhhh, I was at the fitness center for an hour and a half, so kinda.Was the engine warm?
Oil leaks? Fixed? Lmao it's a 6.2, if its leaking it got oil.Now that the oil leaks are fixed, how often do you have to add oil? is there any blow by? if might be a slight amount of oil from valve seals, blow by or simply condensation in the exhaust.
Its an older video, but this is how it would beif it runs smooth and there are no issues I would leave the timing adjustment alone. messing with that could lead to more issues.
for blow by, it doesn't need to push the cap off, just have some. if you see smoke coming out of the fill tube. with the tubing that comes from the CDR disconnected. it might be enough, but I doubt it. my 93 has severe blow by and will blow the cap off with the tubing from the CDR still connected. on acceleration it smokes the same out of the tail pipe or more!
I would suspect condensation or valve seals. your engine is still very healthy compared to mine. I wouldn't worry about the smoke too much. if that's the only issue... drive it and enjoy.
