On today's episode of "Whats up with the K5"
It WAS LITERALLY working this morning 😭😭
If there is a forward switch from the front seat then try that, if it still dont function then Check the fuse.
If fuse is good, hook a jumper wire from a good clean ground on the door and a clean ground to the body or frame then check function of the window.
If motor still does not function then I would imagine have to get the panel removed then check that there is voltage to the switch.
If voltage is good to the switch, disconnect the plug going to the motor, then check that You have voltage each way from the switch, if not replace switch, if so then possibly bad motor.
I really dont know enough about such as this to be giving advice other than basic function tests, if I am wrong then I wiukd hooe someone with more knowledge than I would jump in and auto correct Me. 😹😹😹
Apologies for the delayed update, somehow the jumper cables behind the glass got loose and my window was stuck at that position due to that.
Had to take the glass out, reattach it and thats it. Sprayed the gears, tracks, etc with lubrication though before I put it back together.
It all works now
Hear me out boys, need your opinion
Everytime (on the interstate) when I give it throttle, it ALWAYS shoots out grey/whiteish smoke from the exhaust. Its a haze more than anything.
Now its not excessive/smoking anyone out or anything. But its there, im not even giving/reading excessive boost numbers (close to zero)
ATS Turbo Kit.
Now that the oil leaks are fixed, how often do you have to add oil? is there any blow by? if might be a slight amount of oil from valve seals, blow by or simply condensation in the exhaust.
Oil leaks? Fixed? Lmao it's a 6.2, if its leaking it got oil.
as for the blowby, ive put the cap on the oil feed tube (upside down) and it doesnt budge in the slightest.
