That is good news, and after several months trial run too.
I see in leroydiesel store he has injection pumps. Might see how much his pumps are before sending Yours off.
I did order in a set of his new Bosch injectors. No core required.
That will give me time to shop around and see what I can find for better nozzles than the chinesium ones for the injectors I removed.
I am taking
@brandyn64 advice and reached out to a firearms smith here in town. See if he has an ultrsonic cleaner and if He would be willing to put these components through his cleaner. Put them together and see if they still leak pre pop pressure. Still dont know if I’d want to run them, if they’d carbon up and leak like that in less than 20,000 miles.
That no.7 was leaking so bad it was causing a misfire when the engine was cold. I didnt mind if running sligjtly off before the cylinders warmed up, within about 30 seconds but this was a bad misfire.
