@ Will. No compression test done apparently. Not his first rodeo and so when the IP Cam Drive Gears Woodruff key was inspected and found to be blameless, he knew what was next in the line up of suspects…so, the motor was yanked and along with the heads, the motor‘s been disassembled and inspected. Turns out the bottom end, rods, pistons, piston rings, piston height etc. are all as they were when assembled. Cylinder walls are still cross hatched…
Short history on the motor. Diesel Depot built the motor for 635 with the ‘help’ of ideas and advice of Ian, another former member here, for an attempt to build a 500 hp motor. Thread may still be in the archives…MaxxTorque still has the article “The Best Ever 6.5 Chevy Diesel Rebuild (Vol 1, issue 3) but it requires a membership to get the whole thing. I don’t know if they’re even around to approve new members….
Anyhoo, the build started with a 660, 6.2 NA block. Supposed to have a forged crank but, that along with the Clevite bearings didn’t happen which is how I got it. King bearings used instead failed and the crank was taken out in less than 25K miles (picture below). Still, the intake and exhaust runners along with the manifolds were extrude honed (ported and polished?) and ceramic coatings applied to piston tops and valves and heads (visible in the earlier pic.). Against his advice, I bought the remains off Ted, retained the good stuff (except apparently the valves weren’t good) replaced pistons w/30 over Mahle, rods and rod bearings, Scat Crank turned down for 2 piece rear main, studded the mains, heads and, for grins, the HT-4 Cam etc. etc. and twisted Bill’s arm into doing the work… so much for short story but, those who know me…know.
FWIW, my old motor was a 141 block with 200k plus miles, had been abused by previous owner and my own learning curve. With the cracked heads, an ATT Turbo and one of the many tunes I’ve experimented with it pulled 175hp on the dyno with equally 6.5 abysmal torque.
Never did a dyno pull with the new motor after breaking it in but, it was a good puller though it didn’t really live up to the hype. Still, a couple of members here rode in it and liked the initial results.
