MrMarty51
Set the paper roll into the wood burner stove. That’ll make some BTUs.Ahh the famous toilet paper filter! I like that.
I have seen these from the time I was young. I often wondered how well the oil would flow through the roll of paper.Frantz. Hands down the best outside of getting a centrifuge into high oil pressure or an external driven centrifuge.
Kinda surprised none of the vendors here ever became rep.
And not a specific kit for the 6.5. There is a universal kit though and that probably would be more than sufficient.it doesn't replace the engine oil filter, it's designed to be a bypass oil filter connected to the oil pressure sensor port and drains off into the valve cover or oil fill cap.
I would like to know how fine it filters stuff. the kit is a little over 2 bills online.
Frantz universal kit is $290.00 for the tredlet paper kit.How much is the cost of these kits and filter elements?
FS2500 is a little over $600.00How much is the cost of these kits and filter elements?
Oh yeah, the John Wayne toilet paper.So you want to use toilet paper that is really dense almost hard. You know the stuff that they seem to use in portapotties that you hate to use
Rotella T6 5w40
I have had great results on my UOA with 15W40 T6 on the 6.7 Cummins. It's been unobtainable. So I ordered the AMSOIL and it was dropped on my doorstep ... But they didn't have the oil filter in stock. I did not want to change brands, but, I have a 6 month required oil change due to warranty requirements of the OEM maintenance schedule and unobtainable oil and filters makes this "fun".
Additives in the oil wear out. The VI can sheer so the hot weight becomes too thin. A NV5600 transmission is famous for sheering oil down. TBN is no so much of a factor with the ULSD we have today. But the oil being too thick or too thin is a failure I have run into in the last decade.
Fuel dilution including BioDiesel contamination will thin oil out. Bio doesn't evaporate back out of the oil like #2 diesel can.
Time is generally limited to ONE YEAR regardless of miles even on the fancy AMSOIL oil. Can the cheap made conglomerate bean counters had a field day oil filter handle it without coming apart from age is also a very real concern.
So before you go too crazy on a dirty running engine that requires 2500 mile HD use oil changes ... How many miles per year do you put on it? IMO these engines mostly crack to death before they wear out. Wear is mainly cam bearings and ring tension going away, blowby, from overheating.
