I bet something was dropped through the oil fill tube...
How do the bolts look that go through the backing plate into the pump- any wear on those?
Ip mounting bolt length?
Well, can’t say you never been Elk hunting!
Remember with the timing gears to use gaskets instead of just permatex on components for proper depth of dogbone.
You put more miles on Patch than I put on my Tahoe, but I use the gold spray Permatex stuff on my crossover gaskets amd never have any leaks.Patch has more Elk than most hunters guns!
Yeah gaskets and high temp orange RTV on each side. RTV alone isn't enough for the crossover to head. Need to figure out how to keep that from leaking every couple years.
I use The Right Stuff on everything but the crossover and the rear coolant block off plates for some reason. You’re right, I’m hooked on the stuff and use it whenever I can (it’s really nice for diff covers). The only downside is that it makes valve cover and oil pan removal no fun at all!Permatex “the right stuff”.
It’s the only sealant certified by all the major manufacturers. I have built tons of engines including 6.5s using only front and rear mai seals, head gasket, and the right stuff. No leaks.
When I do mine this time, I will use gaskets for spacing of timing gear dog bone, but a thin wipe of right stuff on both sides of the gasket.
I use right stuff on my crossover, no leaks.
Sustained 450 temp, something like 15 minutes at 500. Sensor safe, impervious to atf, all oils except gas and diesel. Give it a shot, you’ll get hooked like I did.
I must have got a bad batch. Doing a terrible little job, intake on wifeys 88 Buick, 2.8 V6, warming it up good, did not even get it out of the garage, intake started leaking oil. darn.Permatex “the right stuff”.
Haha. Gassers can hear thr [gears] whine much better. We have more metal in the way buffering it and more rattle to disguise it.
The drone of patch muffled by the turbo and glasspack like muffler gets old on long trips. Not going to be easy to hear gear noise. Esp over the 45 MPH howl of the rear end... Make everything else loud enough and you won't notice...
