Will L.
Oh, then no worries. I was thinking over 200 on it.
I'd check out the FFM first
Yeah, that does sound like an injector return line. Probably #6?Wouldn’t that leak down over the transmission to engine connection point? This is dribbling down in line with the CDR onto the starter.
Well, that was a cheap, if not slightly embarrassing, fix to the leak.
Why’s that? Will the cat ruin the belt?Could have been worse. It could have been the cat.
Dont take, only leave. LOLExcept when finishing the third beer after fixing the leak, then you should go take that leak!
