For some reason I missed the post with them cleaned up. Good, disregard the dmso option.
Those heads are desired because the valves flow better. But what precup is in it can determine what turbo it can handle. Read about small precups and using bigger turbo like hx40 by
@WarWagon and when he added the fuel she smoked.
So the precups getting swapped MIGHT be worth considering. Can you get a clear pic of the precup & valve side again now that they are clean?
Since you are staying calm not a power house- staying with the smaller precups might be ok. An hx35, hx40, etc will be easier on the engine than the gm turbo. But added cost of coarse for that. Sticking with the gm turbo is ok. It won’t hurt it, just pay attention to EGT. If you measure in the manifolds and keep at 1,000 or less - the area between the valves shouldn’t crack. Bigger precup & turbo gets the power made with lower egt. So does other stuff like intercooler.
Did this engine come with the db2 on it? If you are running it- I have those square body brand new precups that N8in8or had machined out to diamond precup size for me I would swap. Diamond precups aren’t available individually now (or at least weren’t when we did that). They come installed in new heads. Only ones available now are the triple squares which are just a hair smaller than the diamond. Still plenty good for any turbo, but costs about $260 a set.
As for the tops of the pistons not being coated- don’t worry about that. The coating is definitely better but if ya keep the egt below 1200 sustained a long time the uncoated pistons never gave me a problem. They rarely fail.
