Ok guys, so I sent my just built, siezed, broken shaft .350 plunger pump back to Conestoga and told him to build it with a new .330 head and rotor pump, I recieved it back in May and I just got around to installing it. I've been busy working on my new to me 09 Ram 3500 4x4 Laramie with the 6.7 Cummins ( I really hate working on the 6.5 anymore). Anyhow so I installed the IP and the rebuilt, repoped to 2250 psi injectors (again) friday and wouldn't you guess no fuel output from the IP. So upon further investigation when the head & rotor siezed @ idle on my 20 minute runtime rebuilt pump it sheared the keyway on the IP drive gear on the cam. So I pulled the front of the motor apart and was going to install my Phaser Gear drive that had about 800 miles on it from my old motor but I noticed the brass thrust washer that goes behind the gear on the cam is boogered up. I've called around and I cannot find one and I already have the original P400 gears and chain removed, so unless anyone knows where to source one of these I guess I'll have to just reinstall the OEM chain setup cause I'm not springing for an entire gear drive kit just for a thrust washer. Especially when there is talk about how the harmonics produced by the gear drive are not good for crankshafts on these engines. So the eternal uphill battle continues.
