dbrannon79
I'm getting there!
honestly the way I have mine setup, since that USB adapter is the only thing that gets connected to the truck. I leave the two wires stuck into the ALDL connector under the dash all the time. the USB thing is stuffed into the dash and when I need to connect the laptop, I just pull the USB out and connect it.OK part should be here today I was just thinking that since I already bought the obd1 to obd2 adapter I could Souder the USB port u linked with a couple wires to the obd2 side that way It would be permanent and I could plug in as needed
I have often thought about soldering the two wires making a permanent connection under the dash, getting a USB extension ran and secured somewhere so that the adapter becomes part of the truck harness so to speak. then I only have a USB plug there to connect to for the laptop.
