bison
I'm a little rusty, need some help.
I just replaced the IP on my 98 with ESO straight up, Engine fired up right away so the IP was within perimeters
Initial timing on the AE scantool told me actual and desired timing was 12.
BTDC was 0.35.
I moved the IP to pass side 3 times to a total of 6 mm by now and Act and des timing has moved very little with now 11.1 and TDC is 1.39 but AE don't tell me if it is + or - yes i did relearn with KOKO every time, don't really know wether it took though,temp was at 180.
I try to get the timing to 8.5 actual and TDC to 1.5 ish but i can't turn that damm IP any further than i got it.
Engine seems to run fine.
Kojo ECM
What you say?
BTDC was 0.35.
Kojo ECM
What you say?
