Ds4 fitting for fuel pressure gauge
Sorry, thought you were referencing the youtube video link.
Cost for the fuel pressure gauge set up was not bad.
Gauge: $89.99 for the analog only version, includes sender. It jumps to $129.99 for the analog plus digital. Never have been a fan of digital.
Gauge Pod: $12.99
Mod Mafia T fitting: $30
Colby did the install. I'm waiting to hear back how it's running after he changed out the fuel sender/pick-up in the tank. Sender was very corroded after just 4 years in there, thought it sat for 3 years with a full tank. It seemed to be running well, this on Marty's IP, but until it's road tested......
Probably like this
Im not the guy. I give away every ds4 & pmd I lay my hands on.
DB2 gang for life YO! 😂. Much easier for us with either 5/16 or 3/8 npt fittings.
We add a piece of stainless steel tubing to get out from under the intake manifold and have a T fitting right there where the ffm used to be. I used to fender mount my ffm in pickups. The older trucks that had the rectangular filter - that got thrown away and mount spin on filters set up on the fender.
On the IP the threads under the factory barb fitting is 7/16 orb. you can sub a -4 an male as it uses the same thread and the flare end won't contact anything threading in, just put an o-ring at the base of the male thread. -4 to -6 an hydraulic adapter will work and use gauge port adapter. once there you will need to have a custom fuel hose with the female -6 an or another adapter to barb fitting to use the rubber hose.
Yes Mod Mafia was selling one- it was female flare: male flare w/1/8” Female npt for the sensor. It was for the FTB modded units that have the larger size. Idk if they are still selling them or not.
I ordered the feed the beast kit from Leroy. It came with the ORB to AN fitting that accepts 3/8ths hose barb to AN.
I then ordered the male to female AN fitting that has the 1/8th” pipe for the sending unit.
Humorous & sad (for me) so many "experts" back in the day telling me FTB was waste of time when I came up with the idea, and now so many out there selling kits for it (sadly) I didn't think to patent/sell it, one of the Nay-sayers early on was Bill Heath, yet he wound up with it on the LSR at Bonneville
Do you have a complete parts list and links?
I would like to work on my truck. We're so overwhelmed right now and I'm not doing anything
