The piston will travel back in the bore only as far as the oring will let it travel. Once the piston is pushed out and the oring is settled to tjat position, when the pedal is apllied and the piston pushes outwards, the oring will sort of roll in the groove and against the bore, when the pedal is released, the piston will return only as far as the oring had rolled.
There is no springs or mechanisms that will retract the piston in tje bore, only that springy action of the oring.
I hope that makes sense.
If the piston pushed out too far because of the thinner rotor, and, if the oring would be exposed, brake fluid is going to come dumping out.
Thank You. I get all that, or at least I understand what you are trying to say.
According to the OP, and my own confirmation comparing parts at the part store, there are a few facts. The DRW pads are thicker, and have slightly more surface area than the SRW pads. The DRW rotor is 1/4" thicker than the SRW rotor. The mouth of the DRW caliper is wider to accomodate the thicker pads and the thicker rotor.
The piston is also larger on the DRW caliper than the piston on the SRW caliper.
So it looks like the DRW caliper and pads could be installed on a SRW truck. But the rotors for a 2WD DRW truck have the large offset rim mounting surface which makes installing them on a 2wd SRW truck impracticle compared to just swapping the hat style rotors on a K truck.
So you end up with rotors that are essentially 1/4" narrower than the DRW caliper is designed for when used with the 2WD SRW rotors.
Now, the caliper does not know that the rotor is thinner, and doesn't care at least initially. But it is likely that the pads would need to be changed before they are worn out so that the piston doesn't get too far out of the hole. This would be a fair trade for increased stopping power.
So that leaves the issue of the larger piston of the DRW caliper requiring more fluid for distance of travel, potentially resulting in increased pedal travel. How much? I don't know.
The DRW and SRW call for the same master cylinder as a replacement part so maybe it would be negligible.
I recently replaced the original 290,000 mile rear shoes, and installed the larger DRW rear wheel cylinders.
Pedal travel seemed to increase slightly. But that could be just due to the new shoes not yet matched to the radius arc of the drum, and possibly the old shoes being harder from age and glazing, rather than the extra displacement required for the slightly larger wheel cylinders. And that pedal travel "may" have reduced slightly as the new shoes have worn in this week. Or, I am just adjusting to it.
But I don't want to compound the pedal travel problem with larger displacement calipers as well. This JB8, (or is it JD8?) system has always had a nice high pedal, unlike some of the other trucks with different systems. But despite that it still could have better stopping power.
The larger DRW wheel cylinders definitely help increase rear braking that I can feel.
The fronts are due for a refresh, and I'd like to upgrade them similarly. I "think" I can put the DRW calipers and pads on and get a slightly larger pad surface area as well as the larger piston caliper. The only issue I see is that the pads will need replacing before they're fully worn out to prevent over extension of the caliper piston. And the possibility of increased pedal travel for the larger pistons.
Tom
