Acesneights1
The ATT may not have "LAG" but it builds boost slower, because it flows more exhaust around the compressor than the GMX. So it take a slightly higher fuel input and RPM to achieve the exhaust volume and velocity to get it spinning to see an appreciable amount of boost. This is common to larger compressors designed to be most efficient at higher boost levels and RPM. Some people solve this by running a dual inline, "compound", turbo with one small turbine and one large turbine, or one lower RPM supercharger and a high RPM efficient turbo.
In stock and my engh tune the fuel table has a large spike around idle when you step on it, and then dips significantly before climbing in fuel rate. Heath actually lowers that initial spike and builds fuel output faster after. I have been modifiying my fuel output table and got rid of the most of the thick puff of black smoke when I step on it from a stop.
The IC creates LAG just because the intake is further from the compressor and some restriction. Unless you really like off the line performance its not big deal, just like with ATT its nothing big. You can advance timing until its annoying to start and rattles, to get off the line performance from the engine.
So a 6.2 with a DB2 may not put out enough fuel to properly spool the ATT ?
