So I'll remove the 6.5 IP and toss it and won't need none of the 1996 wiring?
Ahem... sell on ebay or here as a core...
Vbelts or Serp setup going back in?
Are you just swapping the long block in? Trying to go turbo or other major changes?
Suggest re-ring of 6.5 engine because rings are the the only wear item resulting in blowby. As in deglaze cylinders with cordless drill, put new rings in aka overhaul, NOT a rebuild, and don't waste 10 cents on machine work.
Longblock swap staying NA:
Different injector angle on 6.5 heads - bend 6.2 lines carefully. New/rebuilt 6.2 long body injectors?
Timing set has the pickup wheel on the crank - use either set, new, as they both fit.
Recommend gear set as chains stretch out quick.
Oil drain plug will be diffrent side, but, can't swap pans due to crank shaft seal: rope/one piece.
Belt setup makes a difference on waterpump and water pump backing plate due to rotation. Misc holes to plug like turbo oil line and glow plug sensors.
Replace the oil cooler as it has derbis in it waiting to kill the new engine.
