Really good to hear about the cross hatching. I knew there were a few engines out there using different angles, this obviously is one of them and yeah they don't even look like 45 in the pic. The pic between "silicone valley" and heads on the bench looks like 5 degree if anything.
If you don't want to tear it all down here is a quick spot check: pull off the oil pan, he probably over used silicone there anyways, but permetex "the right stuff", which you need for intake anyways.
Get the plastigauge kit ($10-20) summit racing, and only remove two connecting rod caps. Check the clearances there. If one is wrong check them all, and consider checking the mains. If 2 are correct then you can feel better this guy did it ok. You can do any two rods, then just reinstall the pan.
If you feel you want to check the rings, just pull one of the Pistons that you are checking the rod bearings on.
Idk this engine so maybe you would have to buy new front and rear main seals if you pull the crankshaft or the oil pan.
You would also have to pull the timing set to do the main caps correctly.
I might be going overboard here and if forum members think I'm pushing you toward worrying over nothing please speak up. I have rebuilt more engines than I care to remember, and seeing that much silicone told me this guy has never seen what big chunks of it do in the pickup screen - which to me indicates lack of experience. When I saw what looks like no crosshatching in the cylinders is what made me say rip it down those 2 together indicate more likely problems.
I look at the extra silicone as no loss because needing a tube for the upper anyways so no real cost, just time well spent - because no way did this guy silicone one area correct and the other like a first timer.
The plastigauge money is like insurance, you'll be there anyways scraping of the excess silicone.
I used to teach it this way- take a razor blade and cut away the extra interior squished silicone that can come free inside the engine. Pile it up inside a pickup screen. Then show how small of a piece can go through the screen and how well that fits the oil journals.
