Well dang.2001 they changed them.
Thank You.Just get a rear from a 3/4ton. Most have 3.73
Does GV list a unit that fits to the transfer case ?Honestly between my 95 which has 3.73's and the 93 that has 4.10's with the gear vendors OD. I prefer the gear vendors unit. you get the best of both worlds. towing power and highway cruising at low RPM. My 95 has larger tires and with the 3.73's the RPM is still higher than with the 93 and smaller tires! on the 93 when the TCC locks up with the GV OD on, the RPM drops about 400-500 RPM like a full extra gear! I set the TCC to lock up at 55mph since the GV locks in at 45 and it doesn't lug the engine down.
