2002 GMC 2500
Honestly between my 95 which has 3.73's and the 93 that has 4.10's with the gear vendors OD. I prefer the gear vendors unit. you get the best of both worlds. towing power and highway cruising at low RPM. My 95 has larger tires and with the 3.73's the RPM is still higher than with the 93 and smaller tires! on the 93 when the TCC locks up with the GV OD on, the RPM drops about 400-500 RPM like a full extra gear! I set the TCC to lock up at 55mph since the GV locks in at 45 and it doesn't lug the engine down.
Does GV list a unit that fits to the transfer case ?
I’ll have to get back into their website and re check their listings.
I believe they do. iirc it can mount on the transfer case or be a separate unit with a short drive shaft to the t-case/trans. there is wiring for the controller that will "lock out" the front diff function when it's in use, but that is for the electronic 4x4 systems.
Here is the application listing for the 4x4's
I better get to saving some of the money I been earning.
CC below 3500 now so getting mighty close.
The one I have in the 93 was used when the PO bought it. might be able to find one used on market place. even if you find one with a different housing to the trans, you can get the housing from GV and still be ahead except for warranty!
I have thought about looking for one for my son's 68 chevy. he's been thinking about installing that TH-400 but I told him other than getting an automatic that's heavy duty, there'd be no gain for highway gears. He would have to find a 700r4 or a 200r4 if he wanted OD. then the thought occurred to me about the GV unit behind the TH400. a strong trans that we already have and add OD when he's ready!
