Sorry, I forgot the stock part number of
M255294S
This is what came stock in all the piston oil squirter blocks.
The M255HV294S is the one that is 10% more volume and a higher pressure spring.
SO THERE IS 3 OPTIONS
6.2 and non squirter
6.5 with squirter
6.5 with squirter high volume & higher pressure.
Melling has offered the HV pump from the time they made the squirter model.
The maximum allowed pressure spec is 94psi, but is supposed to be 80 psi.
Then this link just texted to me:
So my buddy recently refreshed his 6.5 and we noticed something odd. They show a standard volume pump without a spacer and then a standard volume pump with a spacer and finally a high volume pump which also has a spacer. Turns out the gears on both pumps with spacer are the same and...
www.thetruckstop.us
