Door sticker says 245/75R/16s
With the 285/75R/16s I had to turn the torsion bars way up to keep the 285s from rubbing on the back corner of the fender wells.
I’m afraid that the 265s would do the same.
I want to get the ride height back down to stock.
Plus, narrower tire makes for better traction too.
235/85s are the same height as the 265/75s
Replaced rear sway bar bushings on the 2014 4Runner before it leaves for Montana tomorrow. That truck is running nice and tight and the mileage returned to normal after replacing the MAF sensor.
Doing some planning and I will head up to Montana 3/20 and 3/21 for 3 weeks. Will be hauling my stainless work tables/cabinets. Measured up and I will pull the 2nd row seat and place the bench part on top of the cabinet, which will allow the cabinet to slide in far enough for the barn doors to close.
It is very functional, which is why I love them. A truck with second row seating, but a 6.5’ bed is just not as good. 8’ bed makes that truck unwieldy.
90% of the time, the Suburban is being used as a two row SUV. When you need it, it’s a truck. A truck is always a truck, but the usage as a truck would be the same.
