1994 K3500 extended cab dually
How similar is that to the military version?
Pretty different. I didn’t like how number 5 cylinder was done on the Hummer headers, plus I wanted v-band flanges and I wanted to control the routing of the crossover, so for those reasons I decided to make my own. Ironically, I also don’t love how I did number 5 on mine, ha.
@n8in8or
Could you post a pic of how those flanges fit on the head around the glows and other humps on the mounting surface?
Another question sense you are in the area, if a person used 1 1/4 diameter sch 10 ss pipe and connected 2 cylinders into 1 pipe, do you see room to have 2 crossover tubes, say 1 1/2 diameter ? That way maybe get better use of the firing order ?
@n8in8or
Yes, I can definitely get you some better shots of that for you. I should be able to this evening.
I don't see any reason why dual crossovers couldn't be done. I was mindful of the firing order on the turbo side, making sure 2&4 were on one half of the turbine and 6&8 were on the other side of the turbine. I also attempted to pair 1&3 and 5&7 on the driver side, but I compromised those pairings so I could get the tubes in the space I wanted. I hadn't thought about dual crossovers for a sidewinder.....that's an interesting idea. That would have made construction of the driver side easier.
@n8in8or
Here are some pics. This flange is one I had made for me locally that was a copy of the ones you can get online.
It could use a little touch up with a grinder to get it to align properly.
All this other nonsense stuff like steering and brakes on the way of exhaust… just not right!
That should help a good chunk, definitely need a flex in there for expansion under heat.
