MrMarty51
I believe those are non turbo manifolds.Should I cop?
Log into Facebook
Log into Facebook to start sharing and connecting with your friends, family, and people you know.www.facebook.com
Log into Facebook
I see it now, quite a shame, mine are a bit rustyI believe those are non turbo manifolds.
I mean, at 14K above sea level, id start to behave..... weirdCan I have that Blazer ?
That is a real beauty.
I wonder if a the IP is properly functioning or if a bigger turbo could be installed to supply more air to the intake.
				I wish I had a tachometerI'm curious to know the engine rpm he was running at 25 mph. Might be just lugging the engine
Please keep us posted if You find any info.Ill ask around and see what I can find about the ATS Kit, apparently those were pretty rare, so no surprise theres not much online about it.
some people say they're solid, others say that theyre a bit small and other kits are better, me personally, the turbo has served me well, so I cant say anything too bad about it.
I was able to find a few forums, though its just dead ends, unless I perhaps overlooked something:
ATS turbo kit for 6.2
Hello, I came accross an add on craiglist for a complete ats kit for $300obo. The guy says the turbo needs a rebuild. does anyone know if you can still get these turbo's rebuilt since ats doesn't make these kits anymore? and if this is possible about how much would it cost? Thanks for any...www.dieselplace.com
Someone here claims its non wastegated:
Impressive to me ATS 6.2 turbo
I got my k5 blazer swapped over to a 6.2 that has a Ats turbo on it. No egt gauge on her yet argggg. I do have a boost gauge:rolleyes5:. Engine is a stock gm goodwrench with a db2 pump turned up 1 flat of an allen wrech. timing is advanced by an unknowen amount:eek:. the consern, or should I not...share.google
Someone here actually detailed how to install it + specs:
Ats turbo setup for gm 6.2 https://share.google/X57Qboh3GyghNif54
Thats all I could find, I seem to have decent luck on FB, so ill ask there about the ATS Kit
Yeah, but id like for it to fit the squarebody design, I dont just want to strap a random tachometer on itThere are aftermarket tachometers.
What year is this truck ?Yeah, but id like for it to fit the squarebody design, I dont just want to strap a random tachometer on it
