nycxjeremyy
Missing?Cylinder seems to be missing ? ? ? ?
Crack loose one injection line at time, its like pulling plug wires onna gas enjun.
Any leak on the injection line system will cause rough running.
Yes.Missing?
Not placebo. All those symptoms are right in line with the line being loose.Not sure if its just a placebo affect or not, but ever since I tightened those leaking fittings on the IP, it hasnt smoked the way it has, heck, it even starts smoother now
If there are no wires plgged into the CC unit then you most likely are correct.A bit off topic, but I've always wondered what these connections were for, they were always just there, not connecting to anything.
My cruise control doesn't work, so I can only assume its for thatView attachment 94631View attachment 94632
