That's the plan and the video above, albeit a V6 with manual 6 spd, shows exactly that. So I'm almost there. Did not go into the office, so maybe at lunch today.looking at what room you have between the trans and the radiator, you might be able to twist the trans some along with it looks like you still have a couple of inches of room between the frame and the trans to go up and out.
www.instagram.com
$1550 to get it rebuilt. The shop said if the noise disappears with clutch pedal depressed and trans in neutral, the issue is in the trans. It wasn’t much more (than clutch job) I had to remove to get it out the top.Nice when things go smooth
2nd gear is always a hard shift in these rigs, especially when the transmission is cold and you stomp it.Checked and rechecked the motor and didn't find any source for the diesel that leaked out onto the garage floor. There was no new diesel either. Floor, oil pan and weep hole were dry and this is after a nice drive around town Saturday. Guess that's good news.
Topped up the Radiator Fluid. Changed oil and filter and turned it in to get the transmission a 50K service and diagnostics into why it was slam shifting into 2nd after the batteries died and were recharged. The confirmed that when the batts go down and get recharged it isn't uncommon for things to go wonky for a little while as the servos reset. Good to know.
I had already replaced clutch assembly, throw out bearing and flywheel. Put it back together and the noise I was chasing persisted. Called this manual transmission rebuild shop, described the problem (noise disappears when I depress clutch while it is in neutral) and they said it’s in the transmission. So I pulled the transmission, and brought it in for rebuild. So I already have new clutch everything with just a couple miles on it.I assume while that's being done and the the transmission is out of the vehicle, you'll be replacing the clutch assembly, associated hardware and resurfacing/replacing the flywheel before reinstalling the transmission so you don't have to pull everything back out again in a few years/thousands of miles to do a clutch/throw out bearing/etc.
That's good. And at least you had practice partially pulling the transmission doing the clutch replacement and it was recent enough that you could remember the procedure.I had already replaced clutch assembly, throw out bearing and flywheel. Put it back together and the noise I was chasing persisted. Called this manual transmission rebuild shop, described the problem (noise disappears when I depress clutch while it is in neutral) and they said it’s in the transmission. So I pulled the transmission, and brought it in for rebuild. So I already have new clutch everything with just a couple miles on
