K3500 back in yesterday afternoon.
Left it alone. After helping stepson, then out on snow removal, I’d had enough for one day. This getting older aint for sissies.
I got the shim kit from that Mercedes dealer and the new Bosch injectors arrived. Opened the boxes enough to get a look at the items still wrapped in their packaging, hands was hurting bad so stuffed all the items into one of the boxes and took it all to the garage.
Today, the plan, borrow that OTC Nozzlerater injector tester once again, check leakdown and pop along with spray pattern.
Then, just being cautious here, about dismantling new injectors, shimming to pop at 2100 PSI, or, leave them stock af whatever pressure they are set at.
These are new injectors and warranty will apply but dont know if Bosch marks them so if they are dismantled then whatever they may have applied for marker would be broke and void any warranty.
I guess they are balanced to within 3 to 4 bar, be about 45 PSI.
Time will tell I guess.
Might even be I may not get anything done with any of it today. Hands hurting bad enough it woke me up before 2:00 am. We shall see, seems pain be damned, I have a project, it takes priority, the project does.
