Being as how the intake manifold is removed, I also removed the oil pressure sensor. Went to NAPA and got an extension hose made. 1/4” hydraulic hose with 1/4” male pipe on one end and a 1/4” female pipe on the other end by 28” long.
Screwed a 90* street el into the engine block oil pressure port. Screwed the extension hose into that el and have the female end of the hose hanging about mid firewall.
Next will be to screw the oil pressure sensor into that and have that sensor where it will be obtainable if ever it would start leaking.
First though I need to plug that hose, hook the OP sensor to the air hose through a regulator and have that part of it done.
Next will be to hook the remote start button switch to the started then, turn on the ignition switch, press the start button, rotate the spare IPs shaft K
I'm not sure how the DS4 pump works but I think it will need to see an RPM signal through the PMD for it to start pumping the oil through it.
not exactly sure what type of signal the CPS sends but this intrigues me to want to build a test bench that would run a IP without the engine sort if for this purpose. I would think if you could somehow rig up something to reproduce the CPS signal without cranking the engine like you have it all setup now, that would for sure have it pumping oil. just having the lift pump sending pressure into the IP, you should be seeing some fluid pushing into the return line as long as the LP has enough pressure.
that would be a nice setup. To be able to bolt down and spin the DS4 pump and have it fully functional.
I’m not getting any more done on it today.
Back, legs and hands in enough pain.
I found shims for the injectors. Guess I’ll see what I can find now for nozzles with pintles. I do not want to use chinese nozzles. Not knowing who Bosch is sourcing their nozzles from I’m weary of trying bosch nozzles, injectors too.
Those made in Italy nozzles might be the best thing out there but so far I have not been able to find a source.
