Gotcha. Thank you very much. I'm just a dumb bush equipment meknic/operator and it sounds like it's doable. I'm sure I'll have more questions but until then, thank you very muchIt is not a direct swap. Different cooler line hookups, different shift shaft, mechanical vs cable shift linkage, and a different EPC solenoid and control strategy. And as pointed out, different torque converters.
I do NOT recomend this swap. You will most likely end up buying a different trans controller to make it work.Gotcha. Thank you very much. I'm just a dumb bush equipment meknic/operator and it sounds like it's doable. I'm sure I'll have more questions but until then, thank you very much
Gotcha. Thanks for the inputI do NOT recomend this swap. You will most likely end up buying a different trans controller to make it work.
