Tranny swap
Billybob
Hello and good evening, all.
Here's the story: I have a '93 gm with a 6.5 Detroit. The 4L80E behind it is cooked. I do have a 1998 4L80E from behind a 5.7l that's basically brand new. Would the '98 4L80E fit behind the '93 Detroit? Thanks a bunch
NVW
Castor, AB.
I'm not the one to ask, THEFERMANATOR would be the one. I have a 94 parts truck and the shift mechanism is Mech., later ones were cable. Electronics may differ and the cooler lines are larger on the 98. Also make sure to use the TCC off the diesel.
I do know 95 and later used a different internal/External? wiring harness, updated harnesses can be bought.
THEFERMANATOR
FRANKENBURBAN
Staff member
Lead Moderator
ZEPHYRHILLS FL
It is not a direct swap. Different cooler line hookups, different shift shaft, mechanical vs cable shift linkage, and a different EPC solenoid and control strategy. And as pointed out, different torque converters.
Billybob
Gotcha. Thank you very much. I'm just a dumb bush equipment meknic/operator and it sounds like it's doable. I'm sure I'll have more questions but until then, thank you very much
THEFERMANATOR
FRANKENBURBAN
Staff member
Lead Moderator
ZEPHYRHILLS FL
I do NOT recomend this swap. You will most likely end up buying a different trans controller to make it work.
THEFERMANATOR
FRANKENBURBAN
Staff member
Lead Moderator
ZEPHYRHILLS FL
To make a 97+ trans work with a 93 controller will require a custom valve body. You cannot swap in a 96 or older valve body into a 97+ center lube 4l80e. So you would have to adapt the 91-93 EPC to the 98 valve body. This WILL involve welding, custom milling work, and integrating parts if the 93 valve body into the 98's. And this is if it's a 2 wheel drive, if it's a 4x4 you have to completely tear the 98 trans down to add an output reluctor wheel. This is the kind of swap that known trans shoos won't even attempt, and if they do they will most likely end up with a different trans controller to make it work. 91-93 4l80e's should be considered a different trans from 94+.
Will L.
Boulder City Nv
Probably better to bring both the transmissions to a GOOD shop, which depending where you are someone might be able to recommend, and bring them both transmissions, if they take cores.
Have them completely rebuild yours so it is good for next quarter million miles.
The money they would give you for the other trans - depends how much they could sell it for. So figure out what you could get on Craigslist.
