btfarm
America First!
Sure looks that way...Is it just the pic or is their chunks missing on the 2nd gear on the crank??
Oh yes it is, top of the tier for tools.Picked this up this evening. $250 needs some work but I think it was a good deal.
That's what I like about metal over wood, you can fix your f-upsSo I woke up in the middle of the night thinking about my base for the bandsaw. By welding the piece in the ends I effectively narrowed the base. It worked like it was because the sheet metal corners of the stand could go all the way out to the ends and the rest of it could flex enough to fit on the sides. So after my paint dries I guess I'll be cutting it in half and welding it back together about a 1/2" wider. Kinda sucks because I thought I was about done. Probably would have taken quite a bit less time to just make a new one. Bummer
