DieselAmateur
Howdy all,
So I'm driving home from town, just crested the top of a hill and I hear a sound like something is dragging. I pull over, engine is still running, and turn it off. Look underneath and oil is leaking everywhere. I then see that the starter is completely blown to bits. This is what I heard rubbing/ dragging. After crawling under, I see that holes are blown in both sides of the oil pan. On the passenger side the blowout caused the starter to be completely blown off the block and into pieces, only held on by wires.
Some background:
I drove to southern PA and back yesterday, 240 miles one way, to pick up an equipment trailer. Weighs around 2800 pounds. No problems running down or back. Towing the empty trailer for close to 4 hours was the longest I had ever towed with this truck. All gauges read normal (EGT, boost, trans temp). I tow a 7k mini excavator locally every now and then for construction work, never longer than a 20 minute drive, never an issue.
I change the oil every 3k miles, was due for a change in 800 miles or so. I checked the oil when I filled up with diesel for the ride home, oil pan read full.
Truck has a chip in it, highest boost is around 14 psi
The manual trans was feeling kinda sticky while towing home and this morning, but only in getting it started in the low gears. Thought it was just the MT being finicky, or from running hotter than usual (towing home temps were 180, unloaded was around 150). I have the trans- cool pto cooling fins on the trans which is where my temperature probe is.
New clutch and pilot/ throw out bearings were installed at the end of January 2018
The CDR valve is a little over a year old and doesn't look gummed up or anything suspicious
So my question(s) are: What the &%@#?! could cause this to happen, and is it worth throwing another oil pan on there or is the motor trashed?
Aside from excessive blow by, could anything transmission or flywheel related have caused this? To the best of my knowledge the engine did not suffer from excessive blow by or oil consumption. I was always a quart or a little more shy when I changed the oil, but I figured this was due to oil being left in the cooler and cooler lines etc, since the dipstick always read full. I have never had any blow by gasses come out of the dipstick or anywhere else for that matter.
It appears to me that the pan cannot be pulled as is; my guess is the front diff has to be removed in order to get the entire pan off. Anyone ever do this before?
Am I wasting my time in putting a new pan on, and am better off putting in a new motor?
Part of me wants to pull the pan to see what is going on in the bottom end, as this happened with zero warning and the motor should have a lot of life left.
But if I throw on a new pan, am I playing roulette with the engine, as something had to make this happen and then it could happen again?
Anything else that can cause excessive pressure build up in the crank case? Something with the trubo drain tube, a plugged oil filter?
I'll post some pics when the old camera is done charging. Now off to wash motor oil out of my hair.
thanks
Peter
Some background:
thanks
Peter
		![PB020235[1].JPG PB020235[1].JPG](https://www.thetruckstop.us/forum/data/attachments/42/42669-707d56033e423689e00d04839b6ada64.jpg)
![PB020236[1].JPG PB020236[1].JPG](https://www.thetruckstop.us/forum/data/attachments/42/42670-65a0233959d25eb0934fb792b9806f88.jpg)
![PB020238[1].JPG PB020238[1].JPG](https://www.thetruckstop.us/forum/data/attachments/42/42671-74a9ad8b82e9ca7f10d930852ad4d924.jpg)
![PB020239[1].JPG](/forum/data/attachments/42/42672-55c99c7f547bd2e5a5fbb9ab53448480.jpg)
		![PB030246[1].JPG PB030246[1].JPG](https://www.thetruckstop.us/forum/data/attachments/42/42688-396a7325b3fd54615b056174b28b7666.jpg)
