Wow. Amazed at the lack of knowledge/ info from the supplier.
Whenworking out any new system, make it a point to not call until pen and paper are infront of you. Always start with the name. In this case it would be to never waste time with that guy again. Remember they are a business that hires and fires people. So getting someone that know their stiff is key.
I would start by calling them back and demand “I need someone who knows how to build a complete working system that can answer technical questions and issues as I have already spent money with you guys on parts I can’t use.”
Once you get someone who knows whats up, go from there.
Their videos are kinda informative, sorta. Leading with 1 guy that has 1 year experience and the other has a whopping 1.5 years on their marketing video is, well, intersting. Not bad if target market is kids still in high school. Anyways...
Yes 90* angles are not friendly, but disturbances of flow may be more desirable than lowering the fuel tank or a custom tank. The restrictions in flow of a hard 90 can be accounted for and overcome, espeusince the volume and pressure required here is not that big compared to many other engines. Nice long bends whenever possible- heck yeah!
The pressure regulator mentioned that has increased pressure set by boost could be useable if it fits your design, but for the db you need to find a regulator that has an absolute high setting down stream of it. You have to talk tl one of their knowledgeable people to find out which one that is, if they offer one. Our system is an outdated one compared to rails, so finding one that is designed for diesel could be impossible. There wasn’t one when I was running the beefed up units. I found one that was for gasoline but was rebuildable. So as the diesel mucked it up, I had to rebuild it once a month. I also used gasoline fuel pumps which never lasted 3 months.
The idea of a surge tank is helpful for the once in while issues. The accumulator is similar, but can be the difference of a system when lift pump pressures can’t be obtained. Dual accumulators in tandem being fed pressure by the power steering pump maybe could do it if feed by the higher volume, lower pressure pumps that are otherwise good simply need a boost.
I feel like the abacus guy trying to talk laptop. I just have no clue what is currently available.
If you can find 1 pump that can supply the volume at half the pressure...2 pumps get it done with proper regulation.
If I were in your guys’ position, I would be kicking the door down of
@greenmeanh1 - if he flat out says no- find someone that understands electronics. ALL dc motors are reversible and variable speed by default. Infact most variable & reversable ac motors are dc motors with ac specs applied.
I don’t know enough on motor control to understand how to put a rheostat inline and get it to control flow properly.
There is no such thing as a “x” pressure pump. Either impelled or positive displacement. Regardless, Pumps are volume machines and pressure is a byproduct of resistance to the volume. Up the volume in the same size line and you’ll get your pressure. It just may take bigger or more pumps at once to do it.
My big expensive dream for a 6.5 would be a dry oil pump system. They have stages, and one could easily be the fuel pump. Amazingly better oiling, less shear drag, crankcase in vacuum, oil pressure high enough to filter 1/10 micron through a cf. a stage to replace power steering pump and take its location. I just need dadsy warbucks to buy it for me- haha
Dang it wish I had stayed on top of this stuff.
