Will L.
Moog problem solvers are generally stronger and resistant to breakage much better. But the greasable ones will wear out much quicker if not being greased. The huge grease channels they cut into it cause the grease to go through and lube much better- like large oil journals for crankshafts. Thats how they can last longer. But when they run dry- things go wrong in a hurry.
The large grease journals are also why they survive water crossings much better.
