n8in8or
I’m hoping to participate in the local dirt drags next week so I wanted to reinforce my tie rods before I did a bunch of boosted launches in 4 wheel drive. First thing I did was buy some QA1 tie rod sleeves from Speedway Motors a couple months ago.
This weekend I made some slip-on sleeves to strengthen the rest of the tie rod ends. I bought a chunk of DOM tubing that was .750 ID with a .250 wall thickness. I cut this into 4, 3” long pieces. Then I drilled and tapped 8, 1/4-20 holes in each piece for set screws. Here’s what the sleeves ended up looking like.
Then it was time to install the bits. Unfortunately, I couldn’t get the QA1 sleeves to thread onto the existing tie rod ends due to rusty threads, so I had to go buy new Moog Problem Solver tie rods. I wish I had planned on that ahead of time because I could have saved a crap ton of money by buying them from Rock Auto instead of O’Reilly....ah well. Hopefully somebody reading this learns from my mistake.
I installed the slip-on sleeves on the ends and then screwed them into the QA1 sleeves. I measured the existing tie rod assemblies and made the new assemblies the same length so as not to throw off my alignment. I could have made the slip-on sleeves a little longer, but I didn’t want to interfere with the adjustability of the tie rods.
I tightened everything after installing them on the truck. Then I cleaned them off and threw some black paint on them.
Time to do some boosted launches in 4 wheel drive!!
