Hink
Overkill Is Underrated
I'm glad you asked about the fan. It is just one of the several things that confuses me. I have Kennedys 180* HD clutch and the fan he sold with it. It's a 1997+ 20" 9 blade steel fan that he recommends. Apparently I got one of the last ones available that he says now are sold out.Curious as to what fan blade you are running now? Does it come on and scream when things are warming up? What is the history of the radiator and condenser? New, rodded, etc.?
I found smaller precups limit the fuel I can burn before it just turns to smoke, and, the engine MAP pegs it's readings at ~17PSI. Even with a aftermarket gauge installed later I never got over ~18 PSI of boot out of the ATT with the DS4 hybrid 6.2 with military NA precups. Never ran WMI. IMO the small precups may have spiked the EGT as fuel may have still been burning when the exhaust valve opened.
I think you are running more fuel than I ever could by the ATT boost numbers alone. Possible I had more advanced timing than you are running that affects (lowers) boost as well. The only time I lost temp control with a single T-Stat was lugging too much for the grade, or, 115+ degree dry air and grades. The Gearing on the MT is of interest as it may be lugging you vs. a 4L80E aka my experience of being in 4th when I needed the higher RPM of direct. My goal was to maintain and be able to reach the speed limit on grades while towing a bumper pull 24-28' trailer.
You have no auto trans to cause heat issues. Are you running the AC? Next step is to measure the temperature of the coolant going into and coming out of the radiator. This will help decide if you have a lack of airflow, too small a radiator, or a combo of both.
My confusion; I never hear it. Not really. I've heard a fan in full lock up in a 454 motor home and it was LOUD. I never hear mine. I just told myself that it was because a gasser is quieter than a diesel and it was right at my elbow under the engine cover. But I really expect to hear mine more. Even when I get out and open the hood when it's hot, nope.
I did get one of his fan clutches that were bad and John traded it out for me and it is better, I can FEEL the air moving when I'm looking down on the engine, but again, I expect to hear it.
Radiator is the new (1 1/2 year old) copper core/brass tank that caused the super low temps that started this thread. (that has a leak in it already, btw)
Another confusing thing... I have the square pre-cups too. And I get almost no smoke. I have to really lug it to get anything noticeable. Part of this confusing part is the IP and the amount of fuel that it's pushing to the pre-cups... stock 4911 and when I first installed it several years back on the old motor, the truck would barely start and then barely run. I could just manage to get it to run enough to idle it around the yard to get it out of the way. Then I decided to turn the fuel screw up for some reason and first turned it about 1/4" and it started and ran! What the hell? Then when I put the new motor in with the ATT a few years later, I went to really crank it up and only got another 1/4 turn or so out of it. So 1/2 turn total, is that all it has? Is that normal?
Even with the square pre-cups, EGTs have never really been an issue. Maybe just because ECTs have been my limiting factor here.
I have seen a max peak of 20-22 PSI (needle was fluttering) with the ATT only twice when I really put the hammer down, unloaded up a steep hill out by my place here. Normally I see a max of about 18, like you. I am interested to see what it would do if I can ever get the pre-cups traded out and a better IP.
I always drop it down a gear and keep rpms between 2500-3500 when climbing a grade. I never really let it lug.
No AC
I can IR the coolant hoses but don't really have the means to get temps from the actual coolant itself right now.
I really appreciate you taking the time to go cerebral on this issue for me, WarWagon. I've been able to manage the heat so far (hell, it could be in normal ranges, I don't know, It just seems like it should be cooler!), but I'd really like to not be concerned about it at all so can really use the input.
