Good news is I have boost when cruising at speed on the highway, and the improvement in mileage is significant. Last mpg with new injectors, glow plugs and air filter box restriction removed was 14.1 mpg. After this weeks commuting with boost from the turbo I got 19.2 mpg !!!
Bad news is I still have a trouble with boost falling off. Did some slow throttle roll ons, highway speed and in 3rd gear on a fcountry road. Same results each time.
For RPM I'm correcting for tach off by 200 rpms (tach vs GMTDScan Tech) so RPM below are actual engine RPM's
Below 1,600 RPM no boost
Around 1,66 RPM + some boost but erratic - by 1,700 RPM steady boost 1.5 PSI
1,700 RPM to 1,800 RPM steady boost that rise with RPM At 1,800 RPM 2.5 PSI boost
1,800 RPM to 1,900 RPM steady boost that rises with RPM At 1,900 RPM 3.5 psi boost
1,900 RPM to 2,000 RPM boost build steady with rpm until I hit 2,000. At 2,000 or slightly aboe, boost drops to 0.
If I keep RPM's just below drop ooff I have steady boost just over 4 PSI.
By they way for all the members out there, I got to see the Fermanators '95 Suburban with LB7 and Allison transmission. WOW with a Holy Crap and You've got to be kidding me + a few expletives that can't be used in public. I've seen a few engine swaps , and it's been my experience that you always see where something didn't quite fit or a work around was needed. Not in his ! You pop the hood and it looks like the engine grew there. Except for the air filter box for a high flow filter and some blue silicone hose - it looks factory OEM Really good stuff.
Question For Members:
Leroy's Diesel Walbro pump goes in next weekend. Crawled under the trucvk and took a close look with pump in hand. Hookm up to the front hard line to the top of the pump looks pretty simple and there is plenty of play to move it around. Rear hard pines looks a little trickier with the barb fitting. I was think of looping a section of hose around the back of the pump with a 90 and barb going into the base of the pump with the barb pointing foward. Any Suggestions?
