Sweet! I'm glad there's a happy end to the story. You were sure to use some Lock-Tite on the new GP, right?![]()
But was it the regular red, or the GOOD 272? You don't want that thing ever coming out again do you?Haha, yea, I'm pretty sure we used Red!![]()
Wow! That is hilarious sold the truck! Glad you got I fixed. As far as not changing anymore, maybe you should just do the rest now while your in practice.:lmao:
Glad to see you got it James. Has to be a big relief. FWIW, I had 2 fail at 200k on the left bank and one at 260k on the right bank so the OEM units hold up a long time.
Oh joy...GP #4 just went out!!
I need to borrow Will's crystal ball. :hihi:
Or he's been down this road before and knows once 1 goes out, the others start droppin like flies!
Well, we got it out yesterday!!
Took just under 2 hours.
I used a Thread I found on another Truck Site googling to see what steps needed to be taken.
Tools needed:
Digital Caliper (So you can know how deep you can Drill before hitting the Electrode in the GP)
Drill
LEFT HAND 13/64" Drill Bit
1/4-20 Bottoming Hole Tap
LEFT HAND 11/32" Drill Bit
Pick Tool / Chisel / whatever you can find or use
Vacuum
Vacuum
Vacuum
Drill the Glow Plug Body Flush to the Head with the 11/32" Drill Bit
Drill the CENTER on the Glow Plug with the 13/64" Drill Bit
Tap the Center of the Glow Plug with the 1/4-20 Bottoming Tap (This is a safety precaution. If you can't get the GP out, you can Thread a Screw into it to then pull it out)
Now use the 11/32" Bit to start drilling out the GP Body completely. You need to be 100% Spot-On so you don't damage the Threads in the Head.
Once you get past the Threads, you should be able to pull the GP out. Before you do that get a Pick Tool to get out any remaining Thread Material that may be in the Threads in the Head.
We used a Thread Chaser just to make sure the Threads were still good in the Head, put the new GP in and everything is good.
