bowtiebutler956
Active Member
Your other choice would be as follows:
Is the van worth less than $2500.00? Here is what you can do for $2500.
Looks like my favorite low mile 6.2 dealer Boyce Equipment out of Utah is up to $1500 for a tested low mile 6.2 diesel (up from $950.00 several years ago). Swap heads to 6.5 heads is optional as long as the precups are made larger or swapped. There is someone on here selling used heads for cheap. New rings and you are good to go.
The 6.5 engines do command more money vs. the 6.2 engine. It's not worth more money to get a bored to 6.5 from a 6.2 diesel engine. This is coming from some of the the most cash strapped members on here. I dropped in a 6.2 engine with ARP head studs, oil cooler kit, and a new starter for less than $2000.00. The price has gone up $600 since I did that and I recommend rings ($60 standard to over $300 for gapless P/N S5565) and precup changes since doing that. The differences like oil pan rear main seal, oil cooler line size, etc. are not worth the extra cash to get a used 6.5.
Thanks for the great advice, and it will be something to think about, if the block in the truck ends up being junk. I do like my van, as its been a great service van. It has both an air compressor, and generator mounted inside of it, which has made it very handy for service calls. While it might bring $2500, it would take time to sell it at that price in my part of the country, as older vehicles sell pretty cheap around here.
Do you happen to know what member is selling the heads cheap? If the block does turn out to be ok, it most certainly will need a head, and maybe two. Thanks
Matt
