bowtiebutler956
Active Member
Hello all, this is my first post even though I have been a member 4yrs now. Thats alot of lurking! Anyway, I decided to finally join the fun. Just to give a quick background on myself, I've been an auto mechanic all my life(I'm 39 yrs old), and I'm currently managing a shop that takes care of a fleet of vehicles. Primarily 1 ton Ford vans (gas) with both the 5.4, and 6.8 v10 engines. My diesel experience is very limited.
Back when I joined here I had a 93 K3500 4 door, 4x4, 6.5TD, Auto, and a 88 C30 with a 6.2, 4.56's, and a 4 speed (more like a 3 speed with a granny gear) trans, and a toolbox bed. A little after 300,000 miles the 94 6.5 started getting compression in the cooling system, and with rest of the truck being quite wore out, I deemed it not worthy of a new engine, and sold it. I continued driving the 88 C30, which was really a great truck, but with 4.56 gears, and no od, it topped out between 55-60. Not to mention that a 6.2 NA didn't have much power. I could be outrun by a VW bug. :rolleyes5: Eventually I got a 96 G30 van with a 6.5 NA, and a 4L80E. Even though its a 96, it came from the factory with mechanical DB2 (5088) IP. I believe the 96 G30 was the last year GM put a mechanical IP on the 6.5, but I could be wrong. This has been, and still is a fantastic service van, and runs very strong considering its 6.5 NA.
This brings me to the reason I started this thread. I just got a 93 K2500 extended cab 4x4, with a blown 6.5TD. Actually, I'll be picking it up next weekend, but the deal is done. The truck only has 124,000 miles, and they said it cracked a cylinder head, and the head is currently off the truck. As soon as I get it to my shop, I'll pull the engine out, and try to decide whether its worth messing with this block, by checking for stress cracks in the mains, etc.. If the block is ok, I'll rebuild this engine, if not, I'll pull the 6.5 out of my 96 G30, and put it in the truck. My budget won't allow for anything like a new Optimizer 6500, but it would be nice.
I recently read the 50+ page thread titled "Replacement Turbo" on the development of the ATT turbo, and I must say that was more like reading a book, than a thread!! I read for nearly 4 hours, and WOW, that is some good stuff. Once I'm a little closer to finishing my engine for the truck, I've decided I'll be ordering one. Being that my truck is mechanical, I can't get a KOJO tune. Would a good rebuilt DB2 turned up 1/4 turn, with rebuilt injectors, and a diamond eye exhaust be able to see as good, or close to the same results as a ATT, KOJO tuned, electronic 6.5 does? Any advise is much appreciated. Thanks, and I apologize for getting so long winded.
Matt
Matt
