Well, i found an accumulator spring and was surprised how cheap it was. The guy at the trans shop said they break in 700's all the time. Anyway, I started to reinstall everything and noticed that one of the bolt holes for the accumulator housing bolts had been stripped and helicoiled VERY POORLY. I didn't think much of it and when along reinstalling everything. Started torquing VB bolt and the bolt threaded into the helicoil wouldn't take torque. It pulled the coil out. I figured screw it. It has two more bolts holding it and the helicoil is on the other side of the seperator plate and its not coming out so i just put it all back together. I have to say, I am pleased with the b and m kit. It holds gears longer than before, shifts firmer, and seems to say in the engine's power band more readily. I hope the 700 can hold up while i collect my manual swap parts.
