dbrannon79
I'm getting there!
yeah, mine is a normal ds4 pump. no added fuel at idle or anything less than 50% throttle. plus I drive like grandpa lol except for when I'm running late getting to work
I don't honestly think it's a stuck lifter because before I changed the oil I was running 15-40 along with a quart of lucas oil treatment. the cooler weather lately in the mornings was causing that split second or two if lifter clatter and slow buildup on oil pressure. I dropped the oil out and refiled with Mobil 1 5-40. that stopped the lifter clatter on startup I was hearing. that was a distinctly different clatter sound.
I'm fearing what Will was telling me before back in the summer when I did a compression test and found the passenger side lower than the drivers along with #8 being the lowest of them all. be mentioned stuck rings or a scarred cylinder.
I'm not sure if I can get to the #8 injector by just pulling the inner fender, but I was thinking about trying to swap it with on on the drivers side and see what happens. if I had one of those camera thingamojiggers I would attempt to take a peak through the injector hole too.
