NVW
If only running one at a time I would just use a 1/4" ball valve at each LP. Just open it when that LP is powered.
As kinda sorta similar I have noticed my lowest fuel pressure at IP inlet is when I roll into throttle and let RPM's and throttle rise slower than just mashing the pedal to the floor. The truck seems a little stronger that way too. Probably my IP is old and tired but something about the way boost builds and maybe just maybe how the IP can maintain better optimized timing and complete burn better. It still takes a little more go pedal and upwards of 2600 rpm to to drop to zero fuel pressure. But between 1700 and 2200 it seems to want more too it will drop to 1-2 psi. Which I think is too low for good performance.
I am stock program & factory fuel system (just added guage & and have replaced LP with OE equivalent) and my filter is due for change. As a side note most of the times the flow rating of a filter is when new (and for a certain viscosity -temp and pressure differential) once used and getting plugged its an unknown (I guess it is variable depending on micron sizes and contamination somewhat). A differential guage is probably the easiest way to tell semi accurate cleanliness of filter element (like Kennedy's site).
Holy smoke, Batman!
.... 2 new gauges on order...
Thanx, Matt, for the encouraging thread!:grouphug:
